[gdal-dev] Assistance Required for Downloading GDAL Libraries and Dependencies for aarch64 and Static Compilation on LS1046 ARM64 Processor
Pujitha Uttharkar
pujithau at medha.com
Tue Sep 24 03:24:46 PDT 2024
I hope this message finds you well.
I am reaching out to seek assistance regarding the download and
compilation of GDAL libraries and their dependencies for the aarch64
architecture. Specifically, I am working on a project that requires
static compilation, and I need compatible GDAL libraries and their
static dependencies for cross-compilation on an LS1046 ARM64-based
processor, manufactured by NXP.
Despite setting the appropriate environment variables and paths, I
encountered issues during the cross-compilation process. The error I am
facing is as follows:
medha at L1429:~/Desktop/data/taws_algorithm/codes/QSI/sep24$ export
LD_LIBRARY_PATH=/usr/aarch64-linux-gnu/lib:$LD_LIBRARY_PATH
medha at L1429:~/Desktop/data/taws_algorithm/codes/QSI/sep24$ make
aarch64-linux-gnu-g++ findplacefile.o wrapper.o -lgdal
-L/usr/lib/aarch64-linux-gnu -o my_program
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld:
cannot find /usr/lib/libm.so.6: No such file or directory
cannot find /usr/lib/libmvec.so.1: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [Makefile:18: my_program] Error 1
It appears that the linker is unable to locate certain standard
libraries such as libm.so.6 and libmvec.so.1, which are critical for the
build process.
I would greatly appreciate your guidance on the following:
How to download aarch64-compatible GDAL libraries, along with their
dependencies.
The process for acquiring static library files for GDAL to facilitate
static compilation.
Any suggestions or solutions to address the cross-compilation issue
mentioned above.
The target board I am using is based on the LS1046 processor (ARM64
architecture) from NXP.
Thank you for your time and assistance. I look forward to your prompt
response.
Regards,
Pujitha.U
Medha Servo Drives Pvt. Ltd.
Mobile: +91 6302796207
Email:pujithau at medha.com
web:www.medha.com <https://www.medha.com/>
Disclaimer:The information contained in this e-mail and/or attachments to it may contain confidential data (or) privileged information of Medha. If you are not the intended recipient, any dissemination, use in any manner, review, distribution, printing, copying of the information contained in this e-mail and/or attachments to it are strictly prohibited. If you have received this communication in error, please notify the sender and immediately delete the message and attachments (if any) permanently.
"Please consider the environment before printing this message."
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240924/1971a952/attachment.htm>
