[gdal-dev] GPKG geometry column name expectations with sqlite dialect
Scott
public at postholer.com
Mon Sep 30 12:00:28 PDT 2024
"Geometry Column = ..." in ogrinfo output. If the method returns an
empty string then a special name "_ogr_geometry_" must be used.
That's from the OGR driver docs:
https://gdal.org/en/latest/user/ogr_sql_dialect.html
I've always found it a bit weird as well. If I'm not sure I'll try,
geom, geometry, _ogr_geometry_.
Then, when creating a gpkg, I'll assign a generic name, geometry
Scott
On 9/30/24 11:35, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev wrote:
> Hi,
> I have two geopackage database files that were constructed, somehow, in
> a way that one has a geometry column called ‘geometry’ and the other
> ‘geom’. QGIS nor OGR seem to have much an issue with this. Both handle
> / display all the features in the expected ways. However, for the gpkg
> with the ‘geom’ column name (which I believe is irregular), the usual
> SQLisms (with dialect=sqlite) seem to fail. For the former gpkg, I can
> use the GEOMETRY identifier as documented successfully, however, this
> fails with the latter with an ‘no such column: GEOMETRY’ error. The
> documentation leads me to believe that that identifier _/should/_
> resolve to whatever the geometry column name is, and maybe it does
> internally but then something later goes haywire for opaque reasons. If
> I manually provide the geometry column’s name in the latter case, no
> error is raised but the results are an empty table, but I know there
> should be positive results. At the very least I don’t think this is
> intuitive behavior and I wonder if there’s an OGR bug. Very basic
> usage, nothing special, no arrow interfacing, etc.
> We run a little behind master, at v3.8.1. There were a half dozen or so
> related changes to gpkg / executesql in the meanwhile but nothing stuck
> out to me as addressing this issue, but I could be wrong.
> Willing to supply both .gpkg files and the associated sql query on request.
> Best,
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
