[gdal-dev] [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Mon Sep 30 13:07:30 PDT 2024
Even was right.  It had to do with SQL ingesting the input as a text string and not an identifier.  Thanks for the input everyone.
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Date: Monday, September 30, 2024 at 4:03 PM
To: Even Rouault <even.rouault at spatialys.com>, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] <jesse.r.meyer at nasa.gov>, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: VS: [gdal-dev] [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
This works for me:
ogrinfo -sql "select count(st_area(geom)) from rakennus" mtkmaasto.gpkg
OGRFeature(SELECT):0
  count(st_area(geom)) (Integer) = 5517708
“select st_area(layer.geom)” feels like a blind shot, or have you seen that it works with some database?
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: maanantai 30. syyskuuta 2024 22.56
Vastaanottaja: Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] <jesse.r.meyer at nasa.gov>; Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
Le 30/09/2024 à 21:18, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] a écrit :
Thanks Scott and Even,
Maybe it’s an unexpected interaction with Spatialite, but explicitly providing the geometry column’s name results in bogus outputs.  Is the SQL string wrong somehow?
f"select count(ST_Area('{lyr_name + '.' + geom_column_name}'))". (same outcome if re-arranged as count(…) from lyr_name instead)
ST_Area(some_text) will not work. It expects an identifier (possibly double quoted if that's needed), not a single-quoted string literal.
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240930/0e627b66/attachment.htm>
