[gdal-dev] [BULK] Re: [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Mon Sep 30 12:53:11 PDT 2024
Same outcome:
OGRFeature(SELECT):0
  st_srid('geom') (String) = (null)
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Scott via gdal-dev <gdal-dev at lists.osgeo.org>
Date: Monday, September 30, 2024 at 3:34 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] [BULK] Re: [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Using st_setsrid(geom, null) gives a count of 0. Setting it to 6931
gives a count. Just for fun, run "select st_srid(geometry_column) from
layername"
On 9/30/24 12:28, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] wrote:
> EPSG:6931, so projected in meters.  Expecting a total result well north
> of a few thousand.
gdal-dev mailing list
https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C02%7Cjesse.r.meyer%40nasa.gov%7Cd40ea0093802427c1c6c08dce186f133%7C7005d45845be48ae8140d43da96dd17b%7C0%7C0%7C638633216897832123%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=g9b1ehy1AwacW0DUo%2FHH7dvNoyNxdUFBYwYdRcixqPo%3D&reserved=0<https://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240930/70cda5a7/attachment.htm>
