[gdal-dev] [EXTERNAL] Re: GPKG geometry column name expectations with sqlite dialect
Even Rouault
even.rouault at spatialys.com
Mon Sep 30 12:56:06 PDT 2024
Le 30/09/2024 à 21:18, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] a écrit :
> Thanks Scott and Even,
> Maybe it’s an unexpected interaction with Spatialite, but explicitly
> providing the geometry column’s name results in bogus outputs. Is the
> SQL string wrong somehow?
> /f/"select count(ST_Area('{lyr_name + '.' + geom_column_name}'))".
> (same outcome if re-arranged as count(…) from lyr_name instead)
ST_Area(some_text) will not work. It expects an identifier (possibly
double quoted if that's needed), not a single-quoted string literal.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240930/eec1c8f6/attachment.htm>
