[gdal-dev] GDAL 3.11.0 "Eganville" beta1 available for testing
Greg Troxel
gdt at lexort.com
Thu Apr 17 16:50:04 PDT 2025
Even Rouault <even.rouault at spatialys.com> writes:
> those errors are related to the new float16 (RFC100) support. Support
> for that type is a bit weak with some compilers / C/C++ libraries. Can
> you give a try at https://github.com/OSGeo/gdal/pull/12165 ?
Thanks for the quick fix! With that patch, I get a successful build.
I have a few remaining warnings, which I don't claim are new in 3.11,
but they don't seem like incorrect warnings at first glance. The first
file may also have missing std::, resulting in calling the C function abs
rather than C++ std::abs, but that's still not float?
I've trimmed the build log; happy to send the whole thing if helpful.
The rest of it, aside from some harmless-looking cmake warnings, is
clean.
[106/1299] Building CXX object alg/CMakeFiles/alg.dir/gdal_homography.cpp.o
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp: In function 'int GDALGCPsToHomography(int, const GDAL_GCP*, double*)':
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp:265:25: warning: conversion from 'double' to 'int' may change value [-Wfloat-conversion]
265 | if (abs(h_normalized(6, 0)) < 1.0e-15)
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp: In function 'int GDALApplyHomography(const double*, double, double, double*, double*)':
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp:394:13: warning: conversion from 'double' to 'int' may change value [-Wfloat-conversion]
394 | if (abs(w) < 1.0e-15)
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp: In function 'int GDALHomographyTransform(void*, int, int, double*, double*, double*, int*)':
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/alg/gdal_homography.cpp:573:17: warning: conversion from 'double' to 'int' may change value [-Wfloat-conversion]
573 | if (abs(w) < 1.0e-15)
[956/1299] Building CXX object ogr/ogrsf_frmts/sqlite/CMakeFiles/ogr_SQLite.dir/ogrsqlitevirtualogr.cpp.o
In file included from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitesqlfunctionscommon.cpp:22,
from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitesqlfunctions.cpp:34,
from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitevirtualogr.cpp:140:
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp: In function 'void OGRSQLiteREGEXPFunction(sqlite3_context*, int, sqlite3_value**)':
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp:212:62: warning: use of old-style cast to 'const char*' [-Wold-style-cast]
212 | const char *re = (const char *)sqlite3_value_text(argv[0]);
| reinterpret_cast<const char *> ( )
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp:225:63: warning: use of old-style cast to 'const char*' [-Wold-style-cast]
225 | const char *str = (const char *)sqlite3_value_text(argv[1]);
/tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp:233:62: warning: use of old-style cast to 'struct cache_entry*' [-Wold-style-cast]
233 | cache_entry *cache = (cache_entry *)sqlite3_user_data(ctx);
| static_cast< -
