[gdal-dev] GDAL 3.11.0 "Eganville" beta1 available for testing
Even Rouault even.rouault at spatialys.com
Thu Apr 17 17:01:58 PDT 2025
> I have a few remaining warnings, which I don't claim are new in 3.11,
> but they don't seem like incorrect warnings at first glance.  The first
> file may also have missing std::, resulting in calling the C function abs
> rather than C++ std::abs, but that's still not float?
No, std::abs() is fine there. Fixed per
https://github.com/OSGeo/gdal/commit/2d169a75c24aece05be9bba588d50bc055e9b9ac
> [956/1299] Building CXX object ogr/ogrsf_frmts/sqlite/CMakeFiles/ogr_SQLite.dir/ogrsqlitevirtualogr.cpp.o
> In file included from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitesqlfunctionscommon.cpp:22,
>                   from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitesqlfunctions.cpp:34,
>                   from /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqlitevirtualogr.cpp:140:
> /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp: In function 'void OGRSQLiteREGEXPFunction(sqlite3_context*, int, sqlite3_value**)':
> /tmp/work/geography/gdal-lib/work/gdal-3.11.0beta1/ogr/ogrsf_frmts/sqlite/ogrsqliteregexp.cpp:212:62: warning: use of old-style cast to 'const char*' [-Wold-style-cast]
Those ones are related to the use of the old PCRE library. Should be
fixed per
https://github.com/OSGeo/gdal/commit/0e38a13e0c7784ddde0361d57d508b8e16fdd4b4
, but you should consider using PCRE2 instead
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250418/1babdd0a/attachment.htm>
