[gdal-dev] GDAL 3.11.0 "Eganville" beta1 available for testing
    Greg Troxel
    gdt at lexort.com
    Thu Apr 17 17:28:26 PDT 2025
Even Rouault <even.rouault at spatialys.com> writes:
> No, std::abs() is fine there. Fixed per
> https://github.com/OSGeo/gdal/commit/2d169a75c24aece05be9bba588d50bc055e9b9ac
great, thanks.
> Those ones are related to the use of the old PCRE library. Should be
> fixed per
> https://github.com/OSGeo/gdal/commit/0e38a13e0c7784ddde0361d57d508b8e16fdd4b4
> , but you should consider using PCRE2 instead
Flipped to pcre2 and all seems ok; thanks for pointing that out.  I
missed the new pcre2 support/deprecation of pcre in 2022 -- but it is in
the NEWS I pasted into the commit log :-)
I'm rebuilding pdal, qgis, and will actually run this, but it looks good
from here and I'll be testing the later betas/rcs as they come.
