[gdal-dev] [External] : Re: Build failed with "cannot deduce template arguments" error
Even Rouault
even.rouault at spatialys.com
Wed Apr 30 03:16:57 PDT 2025
GCC 8 release notes indicate that C++17 support is still be a bit
experimental for the standard library. Anyway, can you try
https://github.com/OSGeo/gdal/pull/12231 ? I don't have access to your
compiler so I couldn't check with it, but I'd assume it should make
template deduction easier for the compiler.
Le 30/04/2025 à 05:10, Fengting Chen a écrit :
> I am using “c++ (GCC) 8.5.0 20210514 (Red Hat 8.5.0-18.0.6)” which is
> supposed to support C++17.
> *From: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Tuesday, April 29, 2025 at 6:10 PM
> *To: *Fengting Chen <fengting.chen at oracle.com>,
> gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *[External] : Re: [gdal-dev] Build failed with "cannot
> Which compiler and compiler version do you use ? It is likely it is
> too old and doesn't fully support C++17
> Le 29/04/2025 à 23:18, Fengting Chen via gdal-dev a écrit :
> Hi, I am trying to build GDAL from the master branch, but got the
> following error:
> [ 46%] Building CXX object
> alg/CMakeFiles/alg.dir/gdal_interpolateatpoint.cpp.o
> In file included from
> /scratch/gdal/gdal/alg/gdal_interpolateatpoint.cpp:20:
> /scratch/gdal/gdal/gcore/gdal_vectorx.h: In member function
> ?~@~Xgdal:: VectorX<T, N>::self_type gdal::VectorX<T,
> N>::operator+(T) const?~@~Y:
> /scratch/gdal/gdal/gcore/gdal_vectorx.h:173:44: error: cannot
> deduce template arguments for ?~@~Xplus?~@~Y from ()
> return operatorImpl(arg, std::plus());
> My configuration is:
> -- Target system: Linux
> -- Installation directory: /usr/local
> -- C++ Compiler type: GNU
> -- C compile command line: /bin/cc
> -- C++ compile command line: /bin/c++
> -- CMAKE_C_FLAGS: -fvisibility=hidden
> -- CMAKE_CXX_FLAGS: -fvisibility=hidden
> -- CMAKE_CXX17_STANDARD_COMPILE_OPTION: -std=c++17
> -- CMAKE_CXX17_EXTENSION_COMPILE_OPTION: -std=gnu++17
> -- CMAKE_EXE_LINKER_FLAGS:
> -- CMAKE_MODULE_LINKER_FLAGS: -Wl,--no-undefined
> -- CMAKE_SHARED_LINKER_FLAGS: -Wl,--no-undefined
> -- CMAKE_STATIC_LINKER_FLAGS:
> Any idea on how to fix the error?
> Thanks!
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw1UapGVT$>
> http://www.spatialys.com <https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw2hmL07K$>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250430/b7024fa0/attachment-0001.htm>
