[gdal-dev] [External] : Re: Build failed with "cannot deduce template arguments" error
Fengting Chen
fengting.chen at oracle.com
Tue Apr 29 20:10:09 PDT 2025
I am using “c++ (GCC) 8.5.0 20210514 (Red Hat 8.5.0-18.0.6)” which is supposed to support C++17.
Date: Tuesday, April 29, 2025 at 6:10 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [External] : Re: [gdal-dev] Build failed with "cannot deduce template arguments" error
Which compiler and compiler version do you use ? It is likely it is too old and doesn't fully support C++17
Le 29/04/2025 à 23:18, Fengting Chen via gdal-dev a écrit :
Hi, I am trying to build GDAL from the master branch, but got the following error:
[ 46%] Building CXX object alg/CMakeFiles/alg.dir/gdal_interpolateatpoint.cpp.o
In file included from /scratch/gdal/gdal/alg/gdal_interpolateatpoint.cpp:20:
/scratch/gdal/gdal/gcore/gdal_vectorx.h: In member function ?~@~Xgdal:: VectorX<T, N>::self_type gdal::VectorX<T, N>::operator+(T) const?~@~Y:
/scratch/gdal/gdal/gcore/gdal_vectorx.h:173:44: error: cannot deduce template arguments for ?~@~Xplus?~@~Y from ()
return operatorImpl(arg, std::plus());
My configuration is:
-- Target system: Linux
-- Installation directory: /usr/local
-- C++ Compiler type: GNU
-- C compile command line: /bin/cc
-- C++ compile command line: /bin/c++
-- CMAKE_C_FLAGS: -fvisibility=hidden
-- CMAKE_CXX_FLAGS: -fvisibility=hidden
-- CMAKE_CXX17_STANDARD_COMPILE_OPTION: -std=c++17
-- CMAKE_CXX17_EXTENSION_COMPILE_OPTION: -std=gnu++17
-- CMAKE_EXE_LINKER_FLAGS:
-- CMAKE_MODULE_LINKER_FLAGS: -Wl,--no-undefined
-- CMAKE_SHARED_LINKER_FLAGS: -Wl,--no-undefined
-- CMAKE_STATIC_LINKER_FLAGS:
Any idea on how to fix the error?
Thanks!
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw1UapGVT$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw2hmL07K$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250430/50809d02/attachment-0001.htm>
