[gdal-dev] Build failed with "cannot deduce template arguments" error
Even Rouault
even.rouault at spatialys.com
Tue Apr 29 15:09:59 PDT 2025
Which compiler and compiler version do you use ? It is likely it is too
old and doesn't fully support C++17
Le 29/04/2025 à 23:18, Fengting Chen via gdal-dev a écrit :
> Hi, I am trying to build GDAL from the master branch, but got the
> following error:
> [ 46%] Building CXX object
> alg/CMakeFiles/alg.dir/gdal_interpolateatpoint.cpp.o
> In file included from
> /scratch/gdal/gdal/alg/gdal_interpolateatpoint.cpp:20:
> /scratch/gdal/gdal/gcore/gdal_vectorx.h: In member function
> ?~@~Xgdal:: VectorX<T, N>::self_type gdal::VectorX<T,
> N>::operator+(T) const?~@~Y:
> /scratch/gdal/gdal/gcore/gdal_vectorx.h:173:44: error: cannot deduce
> template arguments for ?~@~Xplus?~@~Y from ()
> return operatorImpl(arg, std::plus());
> My configuration is:
> -- Target system: Linux
> -- Installation directory: /usr/local
> -- C++ Compiler type: GNU
> -- C compile command line: /bin/cc
> -- C++ compile command line: /bin/c++
> -- CMAKE_C_FLAGS: -fvisibility=hidden
> -- CMAKE_CXX_FLAGS: -fvisibility=hidden
> -- CMAKE_CXX17_STANDARD_COMPILE_OPTION: -std=c++17
> -- CMAKE_CXX17_EXTENSION_COMPILE_OPTION: -std=gnu++17
> -- CMAKE_EXE_LINKER_FLAGS:
> -- CMAKE_MODULE_LINKER_FLAGS: -Wl,--no-undefined
> -- CMAKE_SHARED_LINKER_FLAGS: -Wl,--no-undefined
> -- CMAKE_STATIC_LINKER_FLAGS:
> Any idea on how to fix the error?
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250430/61e739be/attachment-0001.htm>
