[gdal-dev] Build failed with "cannot deduce template arguments" error
    Fengting Chen
    fengting.chen at oracle.com
    Tue Apr 29 14:18:28 PDT 2025
Hi, I am trying to build GDAL from the master branch, but got the following error:
[ 46%] Building CXX object alg/CMakeFiles/alg.dir/gdal_interpolateatpoint.cpp.o
In file included from /scratch/gdal/gdal/alg/gdal_interpolateatpoint.cpp:20:
/scratch/gdal/gdal/gcore/gdal_vectorx.h: In member function ?~@~Xgdal::         VectorX<T, N>::self_type gdal::VectorX<T, N>::operator+(T) const?~@~Y:
/scratch/gdal/gdal/gcore/gdal_vectorx.h:173:44: error: cannot deduce template   arguments for ?~@~Xplus?~@~Y from ()
          return operatorImpl(arg, std::plus());
My configuration is:
--   Target system:             Linux
--   Installation directory:    /usr/local
--   C++ Compiler type:         GNU
--   C compile command line:     /bin/cc
--   C++ compile command line:   /bin/c++
--   CMAKE_C_FLAGS:               -fvisibility=hidden
--   CMAKE_CXX_FLAGS:               -fvisibility=hidden
--   CMAKE_CXX17_STANDARD_COMPILE_OPTION:              -std=c++17
--   CMAKE_CXX17_EXTENSION_COMPILE_OPTION:              -std=gnu++17
--   CMAKE_EXE_LINKER_FLAGS:
--   CMAKE_MODULE_LINKER_FLAGS:               -Wl,--no-undefined
--   CMAKE_SHARED_LINKER_FLAGS:               -Wl,--no-undefined
--   CMAKE_STATIC_LINKER_FLAGS:
Any idea on how to fix the error?
Thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250429/fbfc93fb/attachment.htm>
