[gdal-dev] How can I avoid absolute path to shared libraries in libgdal.so
    Greg Troxel
    gdt at lexort.com
    Wed Apr 30 12:07:21 PDT 2025
"Fox, Shawn D (US) via gdal-dev" <gdal-dev at lists.osgeo.org> writes:
> I'm sure a lot of people have opinions
> about the concept of rpath vs using LD_LIBRARY_PATH.  I'm not
> interested in discussing that.  Our team does have a complicated
> application build and distribution process, and it isn't useful to try
> and explain that.
Duly noted; I will attempt to refrain from discussing LD_LIBRARY_PATH or
asking about your build process in the future...
