[gdal-dev] GetMetadataItem adds empty string to MetadataDomainList
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Aug 8 02:41:16 PDT 2025
Thanks Even!
In the same branch there is a test that is failing: cppcheck_master
https://github.com/jjimenezshaw/gdal/actions/runs/16811268010/job/47616930470
I do not see anything related to my changes.
Is it a flaky test that I can ignore?
Thank you.
On Thu, 7 Aug 2025 at 21:53, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> | Or is there a hidden bug somewhere?
> indeed. Fix in https://github.com/OSGeo/gdal/pull/12892
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250808/2fb66788/attachment.htm>
