[gdal-dev] GetMetadataItem adds empty string to MetadataDomainList
Even Rouault
even.rouault at spatialys.com
Fri Aug 8 02:46:03 PDT 2025
Le 08/08/2025 à 11:41, Javier Jimenez Shaw a écrit :
> Thanks Even!
> In the same branch there is a test that is failing: cppcheck_master
> https://github.com/jjimenezshaw/gdal/actions/runs/16811268010/job/47616930470
> I do not see anything related to my changes.
> Is it a flaky test that I can ignore?
I've fixed those new warnings a few weeks ago. You'll just need to
rebase on top of latest master
> Thank you.
> On Thu, 7 Aug 2025 at 21:53, Even Rouault <even.rouault at spatialys.com>
> wrote:
> Javier,
> | Or is there a hidden bug somewhere?
> indeed. Fix in https://github.com/OSGeo/gdal/pull/12892
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250808/044abf6c/attachment.htm>
