[gdal-dev] GeoJSON to CSV output difference between 3.7 and 3.9
Peter Townsend peter.townsend at maplarge.com
Mon Aug 11 13:56:56 PDT 2025
I was attempting to upgrade a process from 3.7.0 to 3.9.1 with the below
input file, and I triggered one of my automated tests that checks the
output of ogr2ogr to CSV. In 3.7, it listed a LINESTRING, POINT,
MULTILINESTRING, and MULTIPOINT. But in 3.9, I only get the LINESTRING and
MULTILINESTRING. My arguments to ogr2ogr are:
-f CSV -overwrite "path/to/dest" "path/to/input.geojson" -lco
GEOMETRY=AS_WKT
Upon further staring at the input, I realized that the FeatureCollection
isn't exactly up to spec. The LineString and MultiLineString are indeed
features, but the point and multipoint are not. They're just the
"properties" and "geometry" propertes, no feature type. You can see this if
you throw the input contents in your favorite JSON formatter.
My questions are thus, is this just GDAL being more mindful of the GeoJSON
spec? Is there some sort of input option I can add that puts it back in the
less strict mode? Or should I just say okay it's different now and update
the test expectations / fix the input file to be proper features?
Input file contents
{"type":"FeatureCollection","features":[{"type":"Feature","geometry":{"type":"LineString","coordinates":[[-94.12405467406431,31.532690532981295],[-94.12413927511027,31.53269179705642],[-94.12472394824769,31.53266379684319],[-94.1253901251488,31.532584216260403],[-94.12626386218717,31.53250765409404],[-94.12646122620484,31.532481068559832],[-94.12702830386473,31.532404682413407],[-94.12745820329715,31.532340011373883],[-94.1278837022303,31.53225417230333],[-94.12801663488807,31.532224077464026]],"bbox":[-94.12801663488807,31.532224077464026,-94.12405467406431,31.53269179705642]},"properties":{"OBJECTID":672860},"id":672860,"bbox":[-94.12801663488807,31.532224077464026,-94.12405467406431,31.53269179705642]},{"properties":{"OBJECTID":672860},"geometry":{"type":"Point","coordinates":[-94.12604508705837,31.53253712377012]}},{"type":"Feature","geometry":{"type":"MultiLineString","coordinates":[[[-101.97716065893691,35.917790607424394],[-101.96492166952294,35.92341944145871],[-101.96328111127792,35.924204444876075],[-101.96317888931199,35.9242627791969],[-101.96145444125442,35.925273890040636],[-101.95943278022344,35.92651610858149],[-101.94270944261692,35.936602776319525],[-101.94225499817804,35.936848330692534],[-101.94173444194344,35.93708055318282],[-101.94117055871999,35.937277219639974],[-101.9406055541843,35.93742611297405],[-101.94007055779315,35.937526666010086],[-101.93959555813376,35.93758333140084],[-101.93939055354555,35.93759888635054],[-101.93851888963131,35.93760777861841],[-101.92749222311619,35.93752221987603],[-101.92070166616179,35.937523888806176],[-101.91913111170948,35.93750333358548],[-101.91557277681014,35.937551113227535],[-101.91284833324379,35.93762333356804],[-101.90929555275227,35.93768499922985],[-101.88019222237504,35.937471108892964],[-101.87967388920762,35.9374950019738],[-101.87898889120852,35.93757722285602],[-101.87833111111162,35.93771666978525],[-101.87772944226847,35.93789777477344],[-101.87745110906612,35.938002219806336],[-101.87689055718347,35.93824833483556],[-101.87660222343933,35.938411114189336],[-101.87628055672884,35.93861944359893],[-101.87591000210242,35.93888999932645],[-101.87561944529126,35.939121667679956],[-101.8754083321584,35.93930944186905],[-101.87534666649668,35.939367222053065],[-101.87503222312395,35.939705558506226],[-101.87482166412806,35.93996389062501],[-101.87443555455185,35.9405338889124],[-101.87418277684091,35.94102611245161],[-101.87406333099538,35.9413338866233],[-101.87396777823031,35.941639998384105],[-101.87385666399655,35.94226722271857],[-101.87381444528154,35.94281388858156],[-101.87378777499688,35.945784447176976],[-101.87375721923426,35.94690888880215],[-101.87377166591027,35.94780277686722],[-101.87372777826538,35.95167777820621],[-101.87372500106116,35.95175444468064],[-101.87363666511492,35.95428333658291],[-101.87353611207905,35.95565333258113],[-101.87348444695914,35.955991108378335],[-101.87340888875863,35.95688721951025],[-101.87292666576121,35.961394999591604],[-101.87282555858843,35.96186389070637],[-101.87263555481319,35.962423888451944],[-101.87237610790118,35.962958330706016],[-101.87206444173263,35.963437222362465],[-101.87173333513643,35.96385388770119],[-101.8714005530909,35.96418944695049],[-101.8709055523478,35.964592219750266],[-101.87032889137872,35.96498555266435],[-101.87002666509558,35.96515722428614],[-101.86951555526602,35.96538444650541],[-101.86903777840256,35.96556444321965],[-101.8687016650162,35.96566721932265],[-101.8681783315779,35.9657977805032],[-101.86782500083102,35.96586777777662],[-101.86729944432558,35.96593444370925],[-101.86680111224173,35.9659672225386],[-101.83603444533186,35.965868331913455],[-101.83520277706549,35.96586944670659],[-101.83478888893076,35.965885001656346],[-101.83422889118512,35.96593999811701],[-101.8336249992753,35.96605055821396],[-101.83303444576732,35.96620555357371],[-101.83244277746601,35.96641777498042],[-101.83194722258597,35.96664111172214],[-101.83144833636523,35.96691555292755],[-101.83096666750481,35.96723833443104],[-101.83055555657411,35.96757110995728],[-101.83014555391726,35.9679766664802],[-101.82985944324012,35.96831444227731],[-101.82959055644254,35.96869444330877],[-101.82931666937402,35.96918555857396],[-101.829125003188,35.96964111128671],[-101.82898777932556,35.9701066645413],[-101.82891222112492,35.97043777765661],[-101.82886444148298,35.97093333253659],[-101.82883500051373,35.99518111301272],[-101.82881944556415,35.99624722031705],[-101.82882777717575,36.00469555287706],[-101.82881777663393,36.00717111072927],[-101.82875944231321,36.007949444945716],[-101.82866666675193,36.008512219895394],[-101.82848888658562,36.009169999992075],[-101.8284222206529,36.00933833375387],[-101.82819277536647,36.00990333177034],[-101.82792888883984,36.010420002527106],[-101.82771111302539,36.010782779678664],[-101.82753110979176,36.01104499727534],[-101.8255677765624,36.01364444710713],[-101.82532333046306,36.01404499684002],[-101.82509555410678,36.01448944725627],[-101.82485389173088,36.01508944716923],[-101.82469333544424,36.01566110786744],[-101.82460111401991,36.01616000060744],[-101.82456888932745,36.01673055303199],[-101.82455944292262,36.02413944205278],[-101.82455833464877,36.02516777677616],[-101.82460055336365,36.02580777885634],[-101.82468555796932,36.02634611310764],[-101.82474500056394,36.02661389163116],[-101.82488222442637,36.02710166903637],[-101.82511000078264,36.02770222308628],[-101.825541112797,36.028533330696455],[-101.8258516641727,36.02901222235277],[-101.82766333338333,36.031581109903044],[-101.82790666468911,36.031953887596444],[-101.82813333277184,36.032373330139066],[-101.82839888822853,36.03297499898201],[-101.82860388629716,36.03357055276097],[-101.82872610934692,36.03408277738378],[-101.82881222222603,36.034637774858524],[-101.82884888653322,36.035238335427586],[-101.82886000186835,36.037769998014475],[-101.82885166373723,36.05539722422793],[-101.82884722412253,36.05927500277086],[-101.82885944121209,36.05982610824856],[-101.82894333102436,36.060555000411966],[-101.82918444578264,36.06187500022045],[-101.8292333336986,36.06247666906348],[-101.82922888756478,36.06268277540611],[-101.82918610819347,36.06310166381164],[-101.82891111285112,36.064807219059226],[-101.828858887075,36.06541944258101],[-101.82881722249702,36.072543889854806],[-101.8287744431259,36.08245722356031],[-101.82886888761696,36.11044555871712],[-101.82883110851658,36.12643777457388],[-101.82885110960036,36.13981389041392]],[[-101.82471777614252,36.139807775349986],[-101.82466833408967,36.172846110317124],[-101.82464500166512,36.182404998482674],[-101.82463777832709,36.18921388759075],[-101.82461055390557,36.19264499916959],[-101.8246177772436,36.19695222079696],[-101.82460944563176,36.208847780541575],[-101.8245788898693,36.21289388632699],[-101.82457777507615,36.21961055401097],[-101.8245555574448,36.22674722489346],[-101.82456611212356,36.22736833416391],[-101.82454611103985,36.23154500112976],[-101.8245427796991,36.23454333176434],[-101.8245194472745,36.237771114204634],[-101.82452388688927,36.241554441737215],[-101.82452888716024,36.2437866682834],[-101.82460777670153,36.24450777645279],[-101.82484833080376,36.24557611334343],[-101.82489944178671,36.24612555641044],[-101.82484666839306,36.246695554697844],[-101.8247116675978,36.247207779320554],[-101.82453444156799,36.24763611413113],[-101.82438833195694,36.24801110837234],[-101.82424277648296,36.248405556079454],[-101.8236466685671,36.25006333168504],[-101.8232333345695,36.25120111171221],[-101.8231183348577,36.25151722401493],[-101.82300444341989,36.25188500143741],[-101.82289777532004,36.25220722228489],[-101.82284055579215,36.25255499862385],[-101.8228155544378,36.25291555270852],[-101.82284611020006,36.25324221969008],[-101.82290222145414,36.253608334701845],[-101.82298166513246,36.253947225292066],[-101.82310221925187,36.254247221988855],[-101.82325722113086,36.25456666563233],[-101.82356277875476,36.25508499880002],[-101.82383888889012,36.25553999737572],[-101.82400777678889,36.25589778077575],[-101.82417000200566,36.256327223860154],[-101.82428333278705,36.25673833479084],[-101.82433333549633,36.257195556433494],[-101.82431721989049,36.258001108552214],[-101.82431444268653,36.25866888919086],[-101.82430388800789,36.25971666434171],[-101.8242911102621,36.26069221915201],[-101.82420111190505,36.26727944696765],[-101.82415555532978,36.27110166839384],[-101.82415888667072,36.279209441433494],[-101.82413777731314,36.28219888631928],[-101.82413277704225,36.28495222323686],[-101.82412999983828,36.2879477766675],[-101.8241138907517,36.29940388626694],[-101.82409333553105,36.303527779839094],[-101.82402333173847,36.32791110872819],[-101.82404444761512,36.32841500173927],[-101.8240244465315,36.339786113252465],[-101.82400666851497,36.346137220061514],[-101.82399222183895,36.35424722268729],[-101.82399277597601,36.35688555337424],[-101.82397999823027,36.358251109757674],[-101.82398555263804,36.35974499773557],[-101.8239666663475,36.36460833163083],[-101.82396722048456,36.3676633341753],[-101.8239738896854,36.368373887665996],[-101.82393888778911,36.386468890200824],[-101.82388610787616,36.41547333647222],[-101.82388166826138,36.42379944598271],[-101.82385611276992,36.42995055499375],[-101.82384888943209,36.4387561102975],[-101.82383999716399,36.44305555444994],[-101.82380611006086,36.45896110980989],[-101.82379006716069,36.46687981165995]]],"bbox":[-101.97716065893691,35.917790607424394,-101.8228155544378,36.46687981165995]},"properties":{"OBJECTID":995679},"id":995679,"bbox":[-101.97716065893691,35.917790607424394,-101.8228155544378,36.46687981165995]},{"properties":{"OBJECTID":995679},"geometry":{"type":"MultiPoint","coordinates":[[-101.83046171070818,35.96766393814374],[-101.82409599672418,36.302993877651765]]}}]}
3.7 output:
WKT,OBJECTID
"LINESTRING (-94.1240546740643 31.5326905329813,-94.1241392751103
31.5326917970564,-94.1247239482477 31.5326637968432,-94.1253901251488
31.5325842162604,-94.1262638621872 31.532507654094,-94.1264612262048
31.5324810685598,-94.1270283038647 31.5324046824134,-94.1274582032972
31.5323400113739,-94.1278837022303 31.5322541723033,-94.1280166348881
31.532224077464)","672860"
"POINT (-94.1260450870584 31.5325371237701)","672860"
"MULTILINESTRING ((-101.977160658937 35.9177906074244,-101.964921669523
35.9234194414587,-101.963281111278 35.9242044448761,-101.963178889312
35.9242627791969,-101.961454441254 35.9252738900406,-101.959432780223
35.9265161085815,-101.942709442617 35.9366027763195,-101.942254998178
35.9368483306925,-101.941734441943 35.9370805531828,-101.94117055872
35.93727721964,-101.940605554184 35.9374261129741,-101.940070557793
35.9375266660101,-101.939595558134 35.9375833314008,-101.939390553546
35.9375988863505,-101.938518889631 35.9376077786184,-101.927492223116
35.937522219876,-101.920701666162 35.9375238888062,-101.919131111709
35.9375033335855,-101.91557277681 35.9375511132275,-101.912848333244
35.937623333568,-101.909295552752 35.9376849992299,-101.880192222375
35.937471108893,-101.879673889208 35.9374950019738,-101.878988891209
35.937577222856,-101.878331111112 35.9377166697853,-101.877729442268
35.9378977747734,-101.877451109066 35.9380022198063,-101.876890557183
35.9382483348356,-101.876602223439 35.9384111141893,-101.876280556729
35.9386194435989,-101.875910002102 35.9388899993264,-101.875619445291
35.93912166768,-101.875408332158 35.939309441869,-101.875346666497
35.9393672220531,-101.875032223124 35.9397055585062,-101.874821664128
35.939963890625,-101.874435554552 35.9405338889124,-101.874182776841
35.9410261124516,-101.874063330995 35.9413338866233,-101.87396777823
35.9416399983841,-101.873856663997 35.9422672227186,-101.873814445282
35.9428138885816,-101.873787774997 35.945784447177,-101.873757219234
35.9469088888021,-101.87377166591 35.9478027768672,-101.873727778265
35.9516777782062,-101.873725001061 35.9517544446806,-101.873636665115
35.9542833365829,-101.873536112079 35.9556533325811,-101.873484446959
35.9559911083783,-101.873408888759 35.9568872195103,-101.872926665761
35.9613949995916,-101.872825558588 35.9618638907064,-101.872635554813
35.9624238884519,-101.872376107901 35.962958330706,-101.872064441733
35.9634372223625,-101.871733335136 35.9638538877012,-101.871400553091
35.9641894469505,-101.870905552348 35.9645922197503,-101.870328891379
35.9649855526644,-101.870026665096 35.9651572242861,-101.869515555266
35.9653844465054,-101.869037778403 35.9655644432196,-101.868701665016
35.9656672193226,-101.868178331578 35.9657977805032,-101.867825000831
35.9658677777766,-101.867299444326 35.9659344437093,-101.866801112242
35.9659672225386,-101.836034445332 35.9658683319135,-101.835202777065
35.9658694467066,-101.834788888931 35.9658850016563,-101.834228891185
35.965939998117,-101.833624999275 35.966050558214,-101.833034445767
35.9662055535737,-101.832442777466 35.9664177749804,-101.831947222586
35.9666411117221,-101.831448336365 35.9669155529276,-101.830966667505
35.967238334431,-101.830555556574 35.9675711099573,-101.830145553917
35.9679766664802,-101.82985944324 35.9683144422773,-101.829590556443
35.9686944433088,-101.829316669374 35.969185558574,-101.829125003188
35.9696411112867,-101.828987779326 35.9701066645413,-101.828912221125
35.9704377776566,-101.828864441483 35.9709333325366,-101.828835000514
35.9951811130127,-101.828819445564 35.9962472203171,-101.828827777176
36.0046955528771,-101.828817776634 36.0071711107293,-101.828759442313
36.0079494449457,-101.828666666752 36.0085122198954,-101.828488886586
36.0091699999921,-101.828422220653 36.0093383337539,-101.828192775366
36.0099033317703,-101.82792888884 36.0104200025271,-101.827711113025
36.0107827796787,-101.827531109792 36.0110449972753,-101.825567776562
36.0136444471071,-101.825323330463 36.01404499684,-101.825095554107
36.0144894472563,-101.824853891731 36.0150894471692,-101.824693335444
36.0156611078674,-101.82460111402 36.0161600006074,-101.824568889327
36.016730553032,-101.824559442923 36.0241394420528,-101.824558334649
36.0251677767762,-101.824600553364 36.0258077788563,-101.824685557969
36.0263461131076,-101.824745000564 36.0266138916312,-101.824882224426
36.0271016690364,-101.825110000783 36.0277022230863,-101.825541112797
36.0285333306965,-101.825851664173 36.0290122223528,-101.827663333383
36.031581109903,-101.827906664689 36.0319538875964,-101.828133332772
36.0323733301391,-101.828398888229 36.032974998982,-101.828603886297
36.033570552761,-101.828726109347 36.0340827773838,-101.828812222226
36.0346377748585,-101.828848886533 36.0352383354276,-101.828860001868
36.0377699980145,-101.828851663737 36.0553972242279,-101.828847224123
36.0592750027709,-101.828859441212 36.0598261082486,-101.828943331024
36.060555000412,-101.829184445783 36.0618750002204,-101.829233333699
36.0624766690635,-101.829228887565 36.0626827754061,-101.829186108193
36.0631016638116,-101.828911112851 36.0648072190592,-101.828858887075
36.065419442581,-101.828817222497 36.0725438898548,-101.828774443126
36.0824572235603,-101.828868887617 36.1104455587171,-101.828831108517
36.1264377745739,-101.8288511096 36.1398138904139),(-101.824717776143
36.13980777535,-101.82466833409 36.1728461103171,-101.824645001665
36.1824049984827,-101.824637778327 36.1892138875908,-101.824610553906
36.1926449991696,-101.824617777244 36.196952220797,-101.824609445632
36.2088477805416,-101.824578889869 36.212893886327,-101.824577775076
36.219610554011,-101.824555557445 36.2267472248935,-101.824566112124
36.2273683341639,-101.82454611104 36.2315450011298,-101.824542779699
36.2345433317643,-101.824519447274 36.2377711142046,-101.824523886889
36.2415544417372,-101.82452888716 36.2437866682834,-101.824607776702
36.2445077764528,-101.824848330804 36.2455761133434,-101.824899441787
36.2461255564104,-101.824846668393 36.2466955546978,-101.824711667598
36.2472077793206,-101.824534441568 36.2476361141311,-101.824388331957
36.2480111083723,-101.824242776483 36.2484055560795,-101.823646668567
36.250063331685,-101.823233334569 36.2512011117122,-101.823118334858
36.2515172240149,-101.82300444342 36.2518850014374,-101.82289777532
36.2522072222849,-101.822840555792 36.2525549986239,-101.822815554438
36.2529155527085,-101.8228461102 36.2532422196901,-101.822902221454
36.2536083347018,-101.822981665132 36.2539472252921,-101.823102219252
36.2542472219889,-101.823257221131 36.2545666656323,-101.823562778755
36.2550849988,-101.82383888889 36.2555399973757,-101.824007776789
36.2558977807757,-101.824170002006 36.2563272238602,-101.824283332787
36.2567383347908,-101.824333335496 36.2571955564335,-101.82431721989
36.2580011085522,-101.824314442687 36.2586688891909,-101.824303888008
36.2597166643417,-101.824291110262 36.260692219152,-101.824201111905
36.2672794469676,-101.82415555533 36.2711016683938,-101.824158886671
36.2792094414335,-101.824137777313 36.2821988863193,-101.824132777042
36.2849522232369,-101.824129999838 36.2879477766675,-101.824113890752
36.2994038862669,-101.824093335531 36.3035277798391,-101.824023331738
36.3279111087282,-101.824044447615 36.3284150017393,-101.824024446531
36.3397861132525,-101.824006668515 36.3461372200615,-101.823992221839
36.3542472226873,-101.823992775976 36.3568855533742,-101.82397999823
36.3582511097577,-101.823985552638 36.3597449977356,-101.823966666348
36.3646083316308,-101.823967220485 36.3676633341753,-101.823973889685
36.368373887666,-101.823938887789 36.3864688902008,-101.823886107876
36.4154733364722,-101.823881668261 36.4237994459827,-101.82385611277
36.4299505549938,-101.823848889432 36.4387561102975,-101.823839997164
36.4430555544499,-101.823806110061 36.4589611098099,-101.823790067161
36.46687981166))","995679"
"MULTIPOINT ((-101.830461710708 35.9676639381437),(-101.824095996724
36.3029938776518))","995679"
3.9 output:
WKT,OBJECTID
31.532224077464)",672860
36.46687981166))",995679
Peter Townsend
Senior Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250811/8f832ef1/attachment-0001.htm>
