[gdal-dev] Could vector reproject be affected if alternative BLAS/LAPACK implementations are in use?
Even Rouault even.rouault at spatialys.com
Thu Aug 14 01:50:23 PDT 2025
Chris,
BLAS/LAPACK is not a direct dependency of GDAL nor PROJ.  BLAS is a
dependency of libarmadillo, which is an optional dependency of GDAL, but
not involved in vector reprojection. I'd suggest :
- running ldd libgdal.so and check there are not 2 PROJ versions linked
- running under Valgrind to see if there is something interesting showing up
- running under gdb and showing the stack trace where it crashes
Even
Le 14/08/2025 à 00:29, Chris Toney via gdal-dev a écrit :
> Hi,
> Is it possible that vector reproject (via `GDALVectorTranslate()`)
> could be affected if alternative BLAS/LAPACK implementations are
> present (i.e, from Intel MKL or OpenBLAS)?
> "ERROR 1: Reprojection failed" may originate from
> https://github.com/OSGeo/gdal/blob/e48cc4f31f43cf872c036d2c4e65e7368166c34a/apps/ogr2ogr_lib.cpp#L6378.
> This is followed by seg fault.
> The error is reported with GDAL 3.10.3, GEOS 3.13.0, PROJ 9.6.2 on
> Fedora 42. The question is motivated by the issue at:
> https://github.com/USDAForestService/gdalraster/issues/769.
> The same code/inputs test without issue on a wide range of different
> platforms in several CI and package management scenarios. The error
> message and seg fault appear to only occur (sometimes not always) when
> the alternative BLAS/LAPACK are present.
> The code that generates the error is at:
> https://github.com/USDAForestService/gdalraster/blob/d7c620b74a987cbc3f96dec245d37809e09f858a/src/gdal_exp.cpp#L1791
> Input and output datasets are GPKG and reprojection is from NAD83 GCS
> (EPSG:4269) to EPSG:32100.
> Thanks.
> Chris Toney
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
