[gdal-dev] Issue opening RAR archive with non-latin filenames
    Rahkonen Jukka
    jukka.rahkonen at maanmittauslaitos.fi
    Wed Aug 20 13:23:57 PDT 2025
Perhaps the key is in the message "to current locale." When I have seen something similar on Windows and when using my default code page 850, changing the code page into 65001 (UTF-8) has often helped. But I have never met  UTF-16BE data.
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Denis Rykov via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
Lähetetty: keskiviikko 20. elokuuta 2025 23.11
Vastaanottaja: gdal dev
Aihe: [gdal-dev] Issue opening RAR archive with non-latin filenames
Hello,
I’m having trouble opening a RAR archive containing files with non-Latin characters using GDAL:
$ docker run --rm -v `pwd`/arch.rar:/arch.rar:ro -e CPL_DEBUG=ON ghcr.io/osgeo/gdal:ubuntu-full-3.11.3<http://ghcr.io/osgeo/gdal:ubuntu-full-3.11.3> gdalinfo "/vsirar/arch.rar"
VSIARCH: Opening arch.rar
VSIARCH: Pathname cannot be converted from UTF-16BE to current locale.
ERROR 4: `/vsirar/arch.rar' does not exist in the file system, and is not recognized as a supported dataset name.
gdalinfo failed - unable to open '/vsirar/arch.rar'.
It seems the issue is related to the non-Latin filenames in the archive. Using unrar, I can extract the files and list them without any problem.
Is there any workaround to make GDAL handle such RAR archives correctly?
Thank you!
