[gdal-dev] gdal 3.11 python API and PostgreSQL driver
Even Rouault even.rouault at spatialys.com
Fri Aug 22 10:21:04 PDT 2025
Thomas,
are you sure you really used --overwrite in the terminal and not
--overwrite-layer ? The latter one is the one you want to use in this
scenario of opening an existing datasource and overwriting its layer.
And in python this will be overwrite_layer=True
Even
Le 22/08/2025 à 19:13, Thomas Szczurek-Gayant via gdal-dev a écrit :
> Hi,
> I've a question with the python API of gdal 3.11 new programs and
> PostgreSQL driver.
> I can run this in a terminal
> gdal vector convert --overwrite base-cc-evol-struct-pop.csv
> PG:"dbname='insee' port=5432 host='localhost' user='thomas'
> password='xxxxxx' schemas='wip' tables='rp_population_import'"
>  and everything is working fine.
> But if I try from the python API with
> gdal.Run("vector", "convert", format="PostgreSQL", overwrite=True,
> input="base-cc-evol-struct-pop.csv", output="dbname='insee' port=5432
> host='localhost' user='thomas' password='xxxxxxxx' schemas='wip'
> tables='rp_population_import'")
> Python throw this error as if gdal/postgres actually try to create a
> new db:
> ERROR 1: PostgreSQL driver doesn't currently support database creation.
> Please create database with the `createdb' command.
> ERROR 1: PostgreSQL driver failed to create dbname='insee' port=5432
> host='localhost' user='thomas' password=XXXXXXXXXXXX schemas='wip'
> Traceback (most recent call last):
>   File "/home/thomas/repos_git/bd_insee/python/__main__.py", line 63,
> in <module>
> host='localhost' user='thomas' password='xxxxxx' schemas='wip'
>   File
> "/home/thomas/miniforge3/envs/bd_insee/lib/python3.13/site-packages/osgeo/gdal.py",
> line 3353, in Run
>     raise RuntimeError("Algorithm.Run() failed: %s" % GetLastErrorMsg())
> RuntimeError: Algorithm.Run() failed: PostgreSQL driver failed to
> create dbname='insee' port=5432 host='localhost' user='thomas'
> password=XXXXXXXXXXXX schemas='wip' tables='rp_population_import'
> Does anyone have a clue or it's me doing it bad ?
> Thanks !
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250822/70368c6c/attachment.htm>
