[gdal-dev] gdal 3.11 python API and PostgreSQL driver
Thomas Szczurek-Gayant thomas.szczurek at gmail.com
Fri Aug 22 23:08:24 PDT 2025
Ok solved it.
What I was trying to do was simply to copy a csv into a Postgres
database. (db and schema already existing, not the table)
The problem was (in terminal)
old way :
  ogr2ogr PG:"dbname='insee' port=5432 host='localhost' user='thomas'
password='xxxxxxxx' schemas='wip'" test_file.csv
works
new way :
gdal vector convert test_file.csv PG:"dbname='insee' port=5432
host='localhost' user='thomas' password='xxxxxxxx' schemas='wip'"
don't work, I need to add the --append option, even to create the table
from scratch (but is that the intended way ?)
Another problem was that with the Python API, with the :
format=PostgreSQL option
it won't be enough, I still need to specify PG: before my connection
string or gdal will search for a file or directory named as the
connection string.
Thanks a lot !
Le 22/08/2025 à 19:21, Even Rouault a écrit :
> Thomas,
> are you sure you really used --overwrite in the terminal and not
> --overwrite-layer ? The latter one is the one you want to use in this
> scenario of opening an existing datasource and overwriting its layer.
> And in python this will be overwrite_layer=True
> Even
> Le 22/08/2025 à 19:13, Thomas Szczurek-Gayant via gdal-dev a écrit :
>> Hi,
>> I've a question with the python API of gdal 3.11 new programs and
>> PostgreSQL driver.
>> I can run this in a terminal
>> gdal vector convert --overwrite base-cc-evol-struct-pop.csv
>> password='xxxxxx' schemas='wip' tables='rp_population_import'"
>>  and everything is working fine.
>> But if I try from the python API with
>> gdal.Run("vector", "convert", format="PostgreSQL", overwrite=True,
>> input="base-cc-evol-struct-pop.csv", output="dbname='insee' port=5432
>> tables='rp_population_import'")
>> Python throw this error as if gdal/postgres actually try to create a
>> new db:
>> ERROR 1: PostgreSQL driver doesn't currently support database creation.
>> Please create database with the `createdb' command.
>> ERROR 1: PostgreSQL driver failed to create dbname='insee' port=5432
>> host='localhost' user='thomas' password=XXXXXXXXXXXX schemas='wip'
>> Traceback (most recent call last):
>>   File "/home/thomas/repos_git/bd_insee/python/__main__.py", line 63,
>> in <module>
>> overwrite=True, input="base-cc-evol-struct-pop.csv",
>> output="dbname='insee' port=5432 host='localhost' user='thomas'
>> password='xxxxxx' schemas='wip' tables='rp_population_import'")
>>   File
>> "/home/thomas/miniforge3/envs/bd_insee/lib/python3.13/site-packages/osgeo/gdal.py",
>> line 3353, in Run
>>     raise RuntimeError("Algorithm.Run() failed: %s" % GetLastErrorMsg())
>> RuntimeError: Algorithm.Run() failed: PostgreSQL driver failed to
>> create dbname='insee' port=5432 host='localhost' user='thomas'
>> password=XXXXXXXXXXXX schemas='wip' tables='rp_population_import'
>> Does anyone have a clue or it's me doing it bad ?
>> Thanks !
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250823/bbe3074c/attachment.htm>
