[gdal-dev] gdal 3.11 python API and PostgreSQL driver
Even Rouault
even.rouault at spatialys.com
Sat Aug 23 02:35:51 PDT 2025
Thomas,
> gdal vector convert test_file.csv PG:"dbname='insee' port=5432
> host='localhost' user='thomas' password='xxxxxxxx' schemas='wip'"
> don't work, I need to add the --append option, even to create the
> table from scratch (but is that the intended way ?)
--update would also work here (the error message has been updated in the
3.12dev version to tell 'convert: Dataset 'PG:dbname=xxxxx' already
exists. You may specify the --overwrite-layer/--append/--update option'
> Another problem was that with the Python API, with the :
> format=PostgreSQL option
> it won't be enough, I still need to specify PG: before my connection
> string or gdal will search for a file or directory named as the
> connection string.
Yes the PG: prefix must always be used for PostgreSQL connection strings
http://www.spatialys.com
