[gdal-dev] Preventing symbol export in custom GDAL build
David Klaus
dklaus at carlsonsw.com
Wed Dec 10 11:10:18 PST 2025
All,
Thank you for the suggestions. And to clarify: yes this is an MSVC build so
-fvisibility=hidden is not an option. I am currently investigating adding a
def file to curate the symbols exported by the gdal dll. I removed the
decorated symbols and built. The resulting dll still reports the decorated
symbols, but I'm hopeful that this is expected behavior. I'm going to
attempt to remove the libspatialite symbols from the def file and rebuild,
On Wed, Dec 10, 2025 at 1:06 PM Kai Pastor, DG0YT via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> In vcpkg, x64-windows means MSVC.
> And even in the visibility world, you can find libs that get it wrong when
> the attention is exclusively on shared libs.
> (Studying the proposed libspatialite patch, I believe I spotted different
> defaults for visibility in different chunks. Needs more investigation...)
> Am 10.12.25 um 19:02 schrieb Andrew Bell:
> On Wed, Dec 10, 2025 at 12:55 PM Kai Pastor, DG0YT via gdal-dev <
>> Am 10.12.25 um 17:09 schrieb Andrew Bell via gdal-dev:
>> Hi,
>> All symbols that aren't specifically exported should be hidden if when
>> you build the flag "-fvisibility=hidden" is set. See
>> cmake/helpers/configure.cmake.
>> I don't think this will help with MSVC and its dllexport declarations.
> I don't know that this is MSVC. I thought it was a GCC build on Windows,
> but regardless, things are essentially the same (on Windows you *must*
> export all the symbols you want visible). I don't know spatialite, but
> there should be some sort of DLL marker (like CPL_DLL in GDAL) that can be
> turned off when building a static library that you then link into GDAL.
> This may be helpful:
> https://gcc.gnu.org/wiki/Visibility
> <https://gcc.gnu.org/wiki/Visibility>
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251210/68f08bfb/attachment.htm>
