[gdal-dev] Preventing symbol export in custom GDAL build
Kai Pastor, DG0YT
dg0yt at darc.de
Thu Dec 11 00:43:46 PST 2025
The proper fix is modifying libspatialite IMO.
Please confirm if there is an issue with libcurl.
I do not like to see uncertainty being made public and fixes being made
private.
Kai
Am 10.12.25 um 20:10 schrieb David Klaus:
> All,
> Thank you for the suggestions. And to clarify: yes this is an MSVC
> build so -fvisibility=hidden is not an option. I am currently
> investigating adding a def file to curate the symbols exported by the
> gdal dll. I removed the decorated symbols and built. The resulting dll
> still reports the decorated symbols, but I'm hopeful that this is
> expected behavior. I'm going to attempt to remove the libspatialite
> symbols from the def file and rebuild,
> On Wed, Dec 10, 2025 at 1:06 PM Kai Pastor, DG0YT via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
> In vcpkg, x64-windows means MSVC.
> And even in the visibility world, you can find libs that get it
> wrong when the attention is exclusively on shared libs.
> (Studying the proposed libspatialite patch, I believe I spotted
> different defaults for visibility in different chunks. Needs more
> investigation...)
> Am 10.12.25 um 19:02 schrieb Andrew Bell:
>> On Wed, Dec 10, 2025 at 12:55 PM Kai Pastor, DG0YT via gdal-dev
>> Am 10.12.25 um 17:09 schrieb Andrew Bell via gdal-dev:
>>> Hi,
>>> All symbols that aren't specifically exported should be
>>> hidden if when you build the flag "-fvisibility=hidden" is
>>> set. See cmake/helpers/configure.cmake.
>> I don't think this will help with MSVC and its dllexport
>> declarations.
>> I don't know that this is MSVC. I thought it was a GCC build on
>> Windows, but regardless, things are essentially the same (on
>> Windows you *must* export all the symbols you want visible). I
>> don't know spatialite, but there should be some sort of DLL
>> marker (like CPL_DLL in GDAL) that can be turned off when
>> building a static library that you then link into GDAL.
>> This may be helpful:
>> https://gcc.gnu.org/wiki/Visibility
>> Andrew Bell
>> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> David Klaus
> Carlson Software
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251211/32763cb8/attachment.htm>
