[gdal-dev] -allow_projection_difference equivalent in GDAL CLI?
Even Rouault even.rouault at spatialys.com
Fri Dec 19 16:19:47 PST 2025
It all depends what "works" mean for you. For sure
-allow_projection_difference will result in *something*, but that will
be pure garbage. It will completely ignore the CRS information. The
-allow_projection_difference flag is meant for tiles that are
fundamentally in the CRS but coming from different formats/providers
where the CRS don't exactly compare to equal due to mundane
differences.  If you want on-the-fly reprojection, you should rather use
"gdal driver git create" to create a GTI compatible index, since the GTI
driver can perform on-the-fly reprojection.
Le 20/12/2025 à 01:15, Scott a écrit :
> That's kinda why I was asking. This works:
> gdalbuildvrt -allow_projection_difference \
>    result.vrt \
> STACIT:"/vsis3/sentinel-s2-l2a-stac/2025/12/18/S2C_OPER_MSI_L2A_TL_2CPS_20251218T212314_A006718_T11SMA.json":asset=scl
> STACIT:"/vsis3/sentinel-s2-l2a-stac/2025/12/17/S2B_OPER_MSI_L2A_TL_2BPS_20251217T200148_A045870_T10JBQ.json":asset=scl
> This does not:
> gdal raster stack \
> result.vrt --overwrite
> Is there a way to create .vrt with different projections in GDAL cli,
> like gdalbuildvrt does?
> Thanks!
> Scott
> On 12/19/25 15:56, Even Rouault wrote:
>> Le 20/12/2025 à 00:46, Scott a écrit :
>>> Hey Even,
>>> Will do.
>>> In this case I was working with Sentinel L2A. One raster was zone 10
>>> and the other was zone 11, which would cause stack to complain.
>> huh, and what result do you expect from stacking tiles in different
>> UTM zones, when no on-the-fly reprojection is done ... That will
>> result in non sense.
http://www.spatialys.com
