[gdal-dev] -allow_projection_difference equivalent in GDAL CLI?
Scott public at postholer.com
Fri Dec 19 16:36:04 PST 2025
Yes, the raster being created from the.vrt is total garbage.
I was completely unaware of gdal driver gti create. I'm gonna go look
into that.
Apologies for all of the noise on the list!
Scott
On 12/19/25 16:19, Even Rouault wrote:
> It all depends what "works" mean for you. For sure -
> allow_projection_difference will result in *something*, but that will be
> pure garbage. It will completely ignore the CRS information. The -
> allow_projection_difference flag is meant for tiles that are
> fundamentally in the CRS but coming from different formats/providers
> where the CRS don't exactly compare to equal due to mundane
> differences.  If you want on-the-fly reprojection, you should rather use
> "gdal driver git create" to create a GTI compatible index, since the GTI
> driver can perform on-the-fly reprojection.
> Le 20/12/2025 à 01:15, Scott a écrit :
>> That's kinda why I was asking. This works:
>> gdalbuildvrt -allow_projection_difference \
>>    result.vrt \
>> STACIT:"/vsis3/sentinel-s2-l2a-stac/2025/12/18/
>> S2C_OPER_MSI_L2A_TL_2CPS_20251218T212314_A006718_T11SMA.json":asset=scl \
>> STACIT:"/vsis3/sentinel-s2-l2a-stac/2025/12/17/
>> S2B_OPER_MSI_L2A_TL_2BPS_20251217T200148_A045870_T10JBQ.json":asset=scl
>> This does not:
>> gdal raster stack \
>> S2B_OPER_MSI_L2A_TL_2BPS_20251217T200148_A045870_T10JBQ.json":asset=scl \
>> result.vrt --overwrite
>> Is there a way to create .vrt with different projections in GDAL cli,
>> like gdalbuildvrt does?
>> Thanks!
>> Scott
>> On 12/19/25 15:56, Even Rouault wrote:
>>> Le 20/12/2025 à 00:46, Scott a écrit :
>>>> Hey Even,
>>>> Will do.
>>>> In this case I was working with Sentinel L2A. One raster was zone 10
>>>> and the other was zone 11, which would cause stack to complain.
>>> huh, and what result do you expect from stacking tiles in different
>>> UTM zones, when no on-the-fly reprojection is done ... That will
>>> result in non sense.
