[gdal-dev] Do ECW Auto tests get run via any automatic workflow?
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Feb 3 01:09:58 PST 2025
As you can see in
https://github.com/OSGeo/gdal/actions/runs/13092743556/job/36531334316#step:18:14520
"gdrivers/ecw.py::test_ecw_7 SKIPPED (Driver ECW not present)"
So I don't think it is tested. Maybe in a different workflow, but I would
be surprised.
On Mon, 3 Feb 2025 at 09:36, Parveen Sharma via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello
> I am interested in knowing if the ECW tests under in source file indicated
> below are run by automated workflow in GDAL Master branch?
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/
> <https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/ecw.py>*ecw.py
> I was specifically looking to see if `*test_ecw_7*` is being ever run and
> was the run successful?
> Please let me know.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250203/ecdfd812/attachment.htm>
