[gdal-dev] Do ECW Auto tests get run via any automatic workflow?
Daniel Baston dbaston at gmail.com
Mon Feb 3 05:37:53 PST 2025
Hi Parveen,
test_ecw_7 is run (successfully) in the Ubuntu 20.04 configuration:
https://github.com/OSGeo/gdal/actions/runs/13092743556/job/36531334565#step:18:4258
I'm pretty sure this is the only workflow that has ECW available. Some ECW
tests are still skipped because they require a newer version of the ECW SDK
than is available in the test container.
Dan
On Mon, Feb 3, 2025 at 3:36 AM Parveen Sharma via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello
> I am interested in knowing if the ECW tests under in source file indicated
> below are run by automated workflow in GDAL Master branch?
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/
> <https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/ecw.py>*ecw.py
> I was specifically looking to see if `*test_ecw_7*` is being ever run and
> was the run successful?
> Please let me know.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250203/c57e061d/attachment.htm>
