[gdal-dev] Motion: adopt RFC 107 (Re: Call for review on RFC 107: Add OGRLayer::IGetExtent() and OGRLayer::ISetSpatialFilter())
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Feb 10 11:55:37 PST 2025
+1 Javier
On Mon, 10 Feb 2025 at 20:40, Howard Butler via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1
> Howard
> > On Feb 10, 2025, at 9:53 AM, Even Rouault via gdal-dev <
> > Hi,
> > I move to adopt RFC 107
> > Starting with my +1
> > Even
> > Le 06/02/2025 à 22:19, Even Rouault via gdal-dev a écrit :
> >> Hi,
> >> Please review https://github.com/OSGeo/gdal/pull/11814: Add
> >> It could have gone through a pull request business-as-usual, but as
> this impacts a number of drivers, including out-of-tree ones, this is worth
> this small RFC.
> >> Summary
> >> This RFC changes the prototype of the OGRLayer::GetExtent(),
> GetExtent3D(),
> >> SetSpatialFilter() and SetSpatialFilterRect() methods.
> >> Motivation
> >> Originally GetExtent(), SetSpatialFilter() and SetSpatialFilterRect()
> were
> >> designed for a single geometry field. When support for multiple
> geometry fields
> >> was added per :ref:`rfc-41`, alternate virtual methods were added to
> accept a
> >> ``int iGeomField`` argument, but this causes slightly repeating code
> patterns
> >> in most drivers, and omissions of the boilerplate can cause bugs.
> >> Even
> > http://www.spatialys.com
> > My software is free, but my time generally not.
> > gdal-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250210/aabe4d60/attachment-0001.htm>
