[gdal-dev] Motion: adopt RFC 107 (Re: Call for review on RFC 107: Add OGRLayer::IGetExtent() and OGRLayer::ISetSpatialFilter())
Daniel Baston dbaston at gmail.com
Mon Feb 10 12:38:42 PST 2025
+1 Dan
On Mon, Feb 10, 2025 at 3:27 PM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I move to adopt RFC 107
> Starting with my +1
> Even
> Le 06/02/2025 à 22:19, Even Rouault via gdal-dev a écrit :
> > Hi,
> > Please review https://github.com/OSGeo/gdal/pull/11814: Add
> > It could have gone through a pull request business-as-usual, but as
> > this impacts a number of drivers, including out-of-tree ones, this is
> > worth this small RFC.
> > Summary
> > This RFC changes the prototype of the OGRLayer::GetExtent(),
> > GetExtent3D(),
> > SetSpatialFilter() and SetSpatialFilterRect() methods.
> > Motivation
> > Originally GetExtent(), SetSpatialFilter() and SetSpatialFilterRect()
> > were
> > designed for a single geometry field. When support for multiple
> > geometry fields
> > was added per :ref:`rfc-41`, alternate virtual methods were added to
> > accept a
> > ``int iGeomField`` argument, but this causes slightly repeating code
> > patterns
> > in most drivers, and omissions of the boilerplate can cause bugs.
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250210/5848d3c3/attachment.htm>
