[gdal-dev] libgeotiff 1.7.4rc1 available for testing
    Even Rouault
    even.rouault at spatialys.com
    Tue Feb 18 06:58:40 PST 2025
Main reason: doesn't build with GCC 15
Download links:
- https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.tar.gz
- https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.zip
Changelog:
* CMake modernization, automate release generation from tags and
refactor CI (#115)
   - CMake: Bumps the minimum CMake version to 3.13
   - CMake: Add BUILD_SHARED_LIBS matrix for ON and OFF using similar
config for macos-latest, windows-latest, and ubuntu-latest
   - CMake: Modernize CMake configuration to prevent flag/feature leaking
   - CMake: Adds CPack configuration so `package_source` target is
available for dist generation
   - CMake: Updates FindPROJ.cmake with GDAL's recent version
   - CMake: add BUILD_MAN and BUILD_DOC options
   - CMake: Windows PDB install with BUILD_SHARED_LIBS
   - CMake: Remove FindGeoTIFF.cmake
   - Removes 16 year old dead `makefile.mpw`
   - Removes 6 year old dead `makefile.vc`
   - CI: Generates release artifacts and attaches them to every build
   - CI: Creates a release and attaches release artifacts for every tag
of the OSGeo/libgeotiff repository
   - CI: [Attests](https://github.com/actions/attest-build-provenance)
the release artifacts if the `github.repository_owner == OSGeo`
   - CI: Remove Appveyor config
* GTIFGetDefn(): add missing normalization of angular units to degree
   Contrary to what the documentation of GTIFDefn::ProjParm[] mentionned,
   we failed to normalize angular measures to degrees when reading them
   from projection parameters (ProjXXXXXGeoKey's) when ProjCoordTransGeoKey
   was present (but we did normalize them when reading them from the PROJ
   database when there were was only a EPSG PCS code)
   Relates to https://github.com/OSGeo/gdal/issues/10154 and
https://github.com/OSGeo/gdal/pull/10158
* Fix build with GCC 15 (#131)
Even
http://www.spatialys.com
