[gdal-dev] libgeotiff 1.7.4rc1 available for testing
Marco Atzeri
marco.atzeri at gmail.com
Tue Feb 18 23:48:57 PST 2025
On 18/02/2025 15:58, Even Rouault via gdal-dev wrote:
> Hi,
> Main reason: doesn't build with GCC 15
> Download links:
> - https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.tar.gz
built on cygwin with both cmake and autoconf using
gcc (GCC) 15.0.0 20250105
I noticed few discrepancies
cmake
- there is no enabled test ?
- /usr/bin/makegeo.exe is built but there is no manual
- /usr/share/doc/GeoTIFF/* docs are installed
autoconf
- "make check" passes
- /usr/bin/makegeo.exe is not present
- /usr/share/doc/GeoTIFF/* docs are NOT installed
Regards
Marco
