[gdal-dev] libgeotiff 1.7.4rc1 available for testing
    Even Rouault
    even.rouault at spatialys.com
    Wed Feb 19 00:23:13 PST 2025
Le 19/02/2025 à 08:48, Marco Atzeri via gdal-dev a écrit :
> On 18/02/2025 15:58, Even Rouault via gdal-dev wrote:
>> Hi,
>> Main reason: doesn't build with GCC 15
>> Download links:
>> https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.tar.gz
> built on cygwin with both cmake and autoconf using
> gcc (GCC) 15.0.0 20250105
> I noticed few discrepancies
Thanks for the testing. I assume all/most those discrepancies aren't
new? In any case, they don't seem like blockers.
Even
> cmake
> -  there is no enabled test ?
> - /usr/bin/makegeo.exe is built but there is no manual
> - /usr/share/doc/GeoTIFF/* docs are installed
> autoconf
> - "make check" passes
> - /usr/bin/makegeo.exe is not present
> - /usr/share/doc/GeoTIFF/* docs are NOT installed
> Regards
> Marco
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
