[gdal-dev] Zip-Compressed GeoJSON Files?
Simon Eves simon.eves at heavy.ai
Fri Feb 21 15:12:49 PST 2025
Revisiting our geo export options after several years and hit something
weird.
Testing with the command-line tools, this works...
ogr2ogr -f "geojson" /vsigzip//path/to/output.geojson.gz <input>
This does not...
ogr2ogr -f "geojson" /vsizip//path/to/output.geojson.zip <input>
It spits a ton of errors (attached) and while the zip file is created, it
has no files in it.
Am I doing something silly, or is this a bug?
Does anyone really use or expect individually-zipped GeoJSON files anyway?
This is with GDAL 3.7.3. We are updating to 3.11 so I'll try that too.
Simon Eves
Senior Rendering Engineer
+1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250221/04f986f2/attachment.htm>
simon.eves at EVESPC2024:~/dumps/exports$ ogr2ogr -f "geojson" /vsizip/states_z.geojson.zip states_z.geojson
ERROR 6: VSIFWriteL() is not supported on main Zip file or closed subfiles
ERROR 1: Terminating translation prematurely after failed
translation of layer states_z (use -skipfailures to skip errors)
simon.eves at EVESPC2024:~/dumps/exports$ ls -l
total 232
-rw-rw-r-- 1 simon.eves simon.eves 168084 Feb 21 15:01 states_z.geojson
-rw-rw-r-- 1 simon.eves simon.eves     22 Feb 21 15:02 states_z.geojson.zip
simon.eves at EVESPC2024:~/dumps/exports$ unzip -l states_z.geojson.zip
Archive:  states_z.geojson.zip
warning [states_z.geojson.zip]:  zipfile is empty
