[gdal-dev] OSM to GDB
gdisk.mike gdisk.mike at gmail.com
Mon Feb 24 20:49:45 PST 2025
Factor the polynomial completely
6x^2 5x-4
On Mon, Feb 24, 2025, 9:22 AM John Oliver via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> That worked. Thanks.
> *From:* Michael Smith <michael.smith.erdc at gmail.com>
> *Sent:* Thursday, February 20, 2025 1:38 PM
> *To:* John Oliver <john.oliver at rsi-visuals.com>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] OSM to GDB
> ogr2ogr -f OpenFileGDB -spat 39 30 40 41 -nlt MULTIPOLYGON -ds_transaction
> C:\TEMP\TEST5.gdb  C:\TEMP\World_8_3.osm multipolygons
> You need to just pass the single layer to ogr2ogr
> Mike
> *From: *John Oliver <john.oliver at rsi-visuals.com>
> *Date: *Thursday, February 20, 2025 at 1:31 PM
> *To: *Michael Smith <michael.smith.erdc at gmail.com>, "
> gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Subject: *RE: [gdal-dev] OSM to GDB
> Tried the -nlt option and the ERROR did go away, which is promising but
> output is still empty
> C:\Program Files\QGIS 3.34.1>ogr2ogr -f OpenFileGDB -spat 39 30 40 41 -nlt
> MULTIPOLYGON -ds_transaction C:\TEMP\TEST5.gdb  C:\TEMP\World_8_3.osm
> Warning 1: Input datasource uses random layer reading, but output
> datasource does not support random layer writing
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> *Sent:* Thursday, February 20, 2025 1:08 PM
> I believe you need to do this by layer, eg points/lines/etc. One GDB per
> geometry class.
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of John
> Oliver via gdal-dev <gdal-dev at lists.osgeo.org>
> *Reply-To: *John Oliver <john.oliver at rsi-visuals.com>
> *Date: *Thursday, February 20, 2025 at 1:03 PM
> *To: *"gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Subject: *[gdal-dev] OSM to GDB
> Excuse my ignorance. I am not a developer.  But I’m trying what should be
> a relatively simple task.
> I need to extract a subset of OSM to Esri FileGDB format.
> My OSM file is valid:
> C:\Program Files\QGIS 3.34.1>ogrinfo C:\TEMP\World_8_3.osm
> INFO: Open of `C:\TEMP\World_8_3.osm'
>       using driver `OSM' successful.
> 1: points (Point)
> 2: lines (Line String)
> 3: multilinestrings (Multi Line String)
> 4: multipolygons (Multi Polygon)
> 5: other_relations (Geometry Collection)
> But when I try to extract to GDB I get the following:
> -ds_transaction C:\TEMP\TEST4.gdb  C:\TEMP\World_8_3.osm
> ERROR 6: Unsupported geometry type
> Needless to say the created GDB is empty.
> Anyone got any idea how to make ERROR 6 go away and hopefully get some
> output
> _______________________________________________ gdal-dev mailing list
> gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250224/c9206973/attachment.htm>
