[gdal-dev] Is it possible to write custom CRS WKTs within a GeoTiff?
Scott Henderson scottyh at uw.edu
Wed Jan 8 08:44:36 PST 2025
Hello gdal-dev,
I’ve looked around for an answer to this one to no avail and would appreciate any insight from those more familiar with the GeoTiff format. I’d like to be able to store a custom WKT *inside GeoTiff metadata* rather than in an external PAM file. I’ve seen some solutions to add custom entries in the PROJ database to accomplish this, but is that really the only way?
Here is a motivating example, using a WKT that specifies a specific WGS84 realization for a given UTM zone:
INPUT=https://opentopography.s3.sdsc.edu/raster/COP30/COP30_hh/Copernicus_DSM_10_N38_00_W109_00_DEM.tif
OUTPUT=/tmp/Copernicus_DSM_10_N38_00_W109_00_DEM_UTM.tif
CPL_DEBUG=ON \
 GDAL_DISABLE_READDIR_ON_OPEN=EMPTY_DIR \
 gdalwarp -co GEOTIFF_VERSION=1.1 -overwrite -dstnodata 0 -r bilinear -tap -tr 30.0 30.0 -s_srs EPSG:7661 -t_srs utm12N_wgs1150.wkt $INPUT $OUTPUT
Here is the wkt, I’d like for it not to end up in a sidecar file where I might loose it, but embedded in the GTiff:
PROJCRS["WGS84 (G1150) / UTM zone 12N",
    BASEGEOGCRS["WGS 84 (G1150)",
        DYNAMIC[
            FRAMEEPOCH[2001]],
        DATUM["World Geodetic System 1984 (G1150)",
            ELLIPSOID["WGS 84",6378137,298.257223563,
                LENGTHUNIT["metre",1]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433]],
        ID["EPSG",7661]],
    CONVERSION["UTM zone 12N",
        METHOD["Transverse Mercator",
            ID["EPSG",9807]],
        PARAMETER["Latitude of natural origin",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8801]],
        PARAMETER["Longitude of natural origin",-111,
            ID["EPSG",8802]],
        PARAMETER["Scale factor at natural origin",0.9996,
            SCALEUNIT["unity",1],
            ID["EPSG",8805]],
        PARAMETER["False easting",500000,
            LENGTHUNIT["metre",1],
            ID["EPSG",8806]],
        PARAMETER["False northing",0,
            ID["EPSG",8807]],
        ID["EPSG",16012]],
    CS[Cartesian,3],
        AXIS["(E)",east,
            ORDER[1],
            LENGTHUNIT["metre",1,
                ID["EPSG",9001]]],
        AXIS["(N)",north,
            ORDER[2],
                ID["EPSG",9001]]],
        AXIS["ellipsoidal height (h)",up,
            ORDER[3],
                ID["EPSG",9001]]],
    USAGE[
        SCOPE["unknown"],
        AREA["Between 114°W and 108°W, northern hemisphere between equator and 84°N, onshore and offshore. Canada - Alberta; Northwest Territories (NWT); Nunavut; Saskatchewan. Mexico. United States (USA)."],
        BBOX[0,-114,84,-108]],
    REMARK["Custom WKT2 combining UTM_12N with WGS84 (G1150)”]]
Cheers,
Scott
