[gdal-dev] GDAL 3.10.1 RC2 is available (was Re: GDAL 3.10.1 release candidate available)
    Daniel Baston
    dbaston at gmail.com
    Thu Jan  9 11:33:28 PST 2025
Yes, this works (with a directory name of "autotest").
On Thu, Jan 9, 2025 at 2:24 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 09/01/2025 à 20:08, Daniel Baston a écrit :
> > It looks like the packaged gdalautotest snapshot does not include a
> > pytest.ini, which causes many warnings to be generated
> > (PytestUnknownMarkWarning) and also some collection errors such as
> > this one.
> Not sure anyone has done that exercice before ;-) I believe you need to
> unzip it in a "gdalautotest" directory under the GDAL source tree, to
> replicate the exact layout of the git repository, and then run cmake so
> that a $build/gdalautotest directory with the generated pytest.ini file
> is created.
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end,
> this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250109/091e7c9f/attachment.htm>
