[gdal-dev] GDAL 3.10.1 RC2 is available (was Re: GDAL 3.10.1 release candidate available)
Even Rouault even.rouault at spatialys.com
Thu Jan 9 11:24:12 PST 2025
Le 09/01/2025 à 20:08, Daniel Baston a écrit :
> It looks like the packaged gdalautotest snapshot does not include a
> pytest.ini, which causes many warnings to be generated
> (PytestUnknownMarkWarning) and also some collection errors such as
> this one.
Not sure anyone has done that exercice before ;-) I believe you need to
unzip it in a "gdalautotest" directory under the GDAL source tree, to
replicate the exact layout of the git repository, and then run cmake so
that a $build/gdalautotest directory with the generated pytest.ini file
is created.
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
