[gdal-dev] Issue with Custom Transformation Pipeline in GDALReprojectImage
Martin Ždila m.zdila at gmail.com
Thu Jan 9 00:20:06 PST 2025
Dear GDAL developers and users,
I am facing an issue where a custom transformation pipeline defined using
PROJ's +proj=pipeline is not being applied when using GDALReprojectImage.
The pipeline appears in the debug logs (PROJ_TRACE), but the output image
does not reflect the expected transformation.
I have described the issue in detail on StackOverflow, including my code
and debugging observations:
https://stackoverflow.com/questions/79341829/why-is-my-custom-transformation-pipeline-not-applied-with-gdalreprojectimage
If anyone has insights into what might be going wrong or how to resolve
this, I would greatly appreciate your help.
Thank you!
Best regards,
Martin Ždila
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250109/1c4472c3/attachment.htm>
