[gdal-dev] Issue with Custom Transformation Pipeline in GDALReprojectImage
Even Rouault even.rouault at spatialys.com
Thu Jan 9 04:11:55 PST 2025
Martin,
GDALReprojectImage() expects that a correct geotransform is already set
on the target dataset.
You may use GDALSuggestedWarpOutput2() to get a guessed geotransform
Otherwise for full automated way, you may also using the C function
GDALWarp().
By the way, your below pipeline looks wrong
|+proj=pipeline +step +inv +proj=krovak +lat_0=49.5
+lon_0=24.8333333333333 +alpha=30.2881397527778 +k=0.9999 +x_0=0 +y_0=0
+ellps=bessel +step +inv +proj=hgridshift
+grids=Slovakia_JTSK03_to_JTSK.gsb +step +proj=krovak +lat_0=49.5
+ellps=bessel +step +proj=webmerc |
After the 3rd step (+proj=krovak), you are in projected coordinate
space. Applying +proj=webmerc afterwards doesn't make any sense since
the later expects geographic coordinates. You probably want to omit the
3rd step
Even
Le 09/01/2025 à 09:20, Martin Ždila via gdal-dev a écrit :
> Dear GDAL developers and users,
> I am facing an issue where a custom transformation pipeline defined
> using PROJ's +proj=pipeline is not being applied when using
> GDALReprojectImage. The pipeline appears in the debug logs
> (PROJ_TRACE), but the output image does not reflect the expected
> transformation.
> I have described the issue in detail on StackOverflow, including my
> code and debugging observations:
> https://stackoverflow.com/questions/79341829/why-is-my-custom-transformation-pipeline-not-applied-with-gdalreprojectimage
> If anyone has insights into what might be going wrong or how to
> resolve this, I would greatly appreciate your help.
> Thank you!
> Best regards,
> Martin Ždila
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250109/b684a0b3/attachment.htm>
