[gdal-dev] pansharpen subset of multispectral bands
Joe McGlinchy joe at aidash.com
Thu Jan 9 11:27:54 PST 2025
Hello,
I'm wanting to pansharpen only a subset of multispectral bands I have available. Say for instance I have blue-green-red-nir, and a panchromatic band, I can calculate the relative weights to specify when using `gdal_pansharpen` on the full multispectral dataset. If I want to only pansharpen, for example, the red and NIR bands, is it best to perform the pansharpening on the full dataset and only retain the bands I need? Or can i provide only the weights specific to the bands I want to pansharpen? If I can do the latter (which I can, given the parameter set to `gdal_pansharpen`), do I need to recalculate those weights, or only provide the subset of weights for those specific bands?
Many thanks,
Joe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250109/b3850988/attachment.htm>
