[gdal-dev] pansharpen subset of multispectral bands
Even Rouault even.rouault at spatialys.com
Thu Jan 9 12:24:06 PST 2025
Le 09/01/2025 à 20:27, Joe McGlinchy via gdal-dev a écrit :
> Hello,
> I'm wanting to pansharpen only a subset of multispectral bands I have
> available. Say for instance I have blue-green-red-nir, and a
> panchromatic band, I can calculate the relative weights to specify
> when using `gdal_pansharpen` on the full multispectral dataset. If I
> want to only pansharpen, for example, the red and NIR bands, is it
> best to perform the pansharpening on the full dataset and only retain
> the bands I need? Or can i provide only the weights specific to the
> bands I want to pansharpen? If I can do the latter (which I can, given
> the parameter set to `gdal_pansharpen`), do I need to recalculate
> those weights, or only provide the subset of weights for those
> specific bands?
Given the formula at
https://gdal.org/en/stable/drivers/raster/vrt.html#gdal-vrttut-pansharpen
pseudo_panchro[pixel]  =  sum(weight[i]  *  spectral[pixel][i]  for  i=0  to  nb_spectral_bands-1)
ratio  =  panchro[pixel]  /  pseudo_panchro[pixel]
for  i=0  to  nb_spectral_bands-1:
     output_value[pixel][i]  =  input_value[pixel][i]  *  ratio
if you only provide a subset of the input spectral bands, you won't be
able to reconstruct a plausible pseudo_panchro values, hence the scaling
ratio will not be accurate.
If your spectral dataset has bands in the R,G,B,NIR order, you can
achieve what you want with:
$ gdal_pansharpen panchro.tif rgbnir.tif,band=1 rgbnir.tif,band=2
rgbnir.tif,band=3 rgbnir.tif,band=4 out.tif -b 1 -b 4
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250109/74a6aa33/attachment.htm>
