[gdal-dev] Build GDAL PDF Driver with PDFium
Parveen Sharma
sharma1981 at outlook.com
Sun Jan 12 20:40:55 PST 2025
Hello
I am trying to build from GDAL from source using v3.9.3 tag
I plan to use "PDFium" library for building GDAL PDF Dynamic driver and have below 3 questions
Ques 1) Are below a right combination of CMAKE options?
<arg value="-DGDAL_ENABLE_DRIVER_PDF=ON"/>
<arg value="-DGDAL_USE_POPPLER=OFF"/>
<arg value="-DGDAL_USE_PDFIUM=ON"/>
<arg value="-DGDAL_ENABLE_DRIVER_PDF_PLUGIN=ON"/>
In addition I will set option PDFIUM_INCLUDE_DIR to point to Path to an include directory with the ``public/fpdfview.h`` header file and option PDFIUM_LIBRARY to point to
Path to a shared or static library file.
Ques 2) Should I be building PDFium from the "master" branch of below fork by Even Rouault to work with GDAL v3.9.3 ?
https://github.com/rouault/pdfium_build_gdal_3_1
Ques 3) If the answer to (2) point is yes, then can I use above branch for both Windows and Linux?
Please suggest and assist.
Best Regards
Parveen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250113/a8fab0f4/attachment.htm>
