[gdal-dev] Build GDAL PDF Driver with PDFium
    David Klaus
    dklaus at carlsonsw.com
    Mon Jan 13 07:34:16 PST 2025
Parveen,
A couple of years ago my company used the following options to generate a
GDAL PDF dynamic driver for GDAL 3.7.0:
-DGDAL_ENABLE_DRIVER_PDF_PLUGIN=ON
-DGDAL_USE_PDFIUM=ON
-DPDFIUM_INCLUDE_DIR="%~dp0ExtractPDFium\install\include\pdfium"
-DPDFIUM_LIBRARY="%~dp0ExtractPDFium\install\lib\pdfium.lib"
Obviously the include directory and library paths will depend on your
specific folder structure, so you might need to adjust those on your
system. But we were successful in building 3.7.0 with GDAL PDF via dll
using these options and perhaps they will work for you as well. Hopefully
this reply is helpful to you. Best of luck,
On Sun, Jan 12, 2025 at 11:41 PM Parveen Sharma via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello
> I am trying to build from *GDAL from source using v3.9.3 tag*
> I plan to use "PDFium" library for building GDAL PDF Dynamic driver and
> have below 3 questions
> *Ques 1*) Are below a right combination of CMAKE options?
> <arg value="-D*GDAL_ENABLE_DRIVER_PDF=ON*"/>
> <arg value="-D*GDAL_USE_POPPLER=**OFF*"/>
> <arg value="-D*GDAL_USE_PDFIUM*=ON"/>
> <arg value="-D*GDAL_ENABLE_DRIVER_PDF_PLUGIN=ON*"/>
> In addition I will set option *PDFIUM_INCLUDE_DIR *to point to Path to an
> include directory with the ``public/fpdfview.h`` header file and option *PDFIUM_LIBRARY
> *to point to
> Path to a shared or static library file.
> *Ques 2*) Should I be building PDFium from the "*master*" branch of below
> fork by Even Rouault to work with GDAL *v3.9.3 ?*
> https://github.com/rouault/pdfium_build_gdal_3_1
> <https://github.com/rouault/pdfium_build_gdal_3_1>
> *Ques 3*) If the answer to (2) point is yes, then can I use above branch
> for both Windows and Linux?
> Please suggest and assist.
> Best Regards
> Parveen
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250113/c8b6934b/attachment.htm>
