[gdal-dev] Build GDAL PDF Driver with PDFium
Even Rouault
even.rouault at spatialys.com
Mon Jan 13 16:03:48 PST 2025
Le 14/01/2025 à 00:26, Parveen Sharma via gdal-dev a écrit :
> Thanks
> What about the PDFium git repo which I mentioned? Do I need to build
> PDFium using that git repo only?
yes, as documented in
https://gdal.org/en/stable/drivers/raster/pdf.html#pdfium. There are
multiple patches needed on top of upstream PDFium to get it compatible
with the GDAL PDF driver
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250114/3bad501f/attachment.htm>
