[gdal-dev] Build GDAL PDF Driver with PDFium
Parveen Sharma
sharma1981 at outlook.com
Mon Jan 13 16:23:05 PST 2025
Thanks Even
As i am building GDAL 3.9.3, so i will use the scripts in the https://github.com/rouault/pdfium_build_gdal_3_9 repository to build a patched version of PDFium.
Would you recommend using the "master" OR the "pdfium_6309_v1" branch of the above repository? I need to build GDAL with PDF Dynamic driver in both Windows and Linux.
Best regards,
Parveen
Sent: Tuesday, January 14, 2025 8:03 AM
To: Parveen Sharma <sharma1981 at outlook.com>; David Klaus <dklaus at carlsonsw.com>
Cc: Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Build GDAL PDF Driver with PDFium
Le 14/01/2025 à 00:26, Parveen Sharma via gdal-dev a écrit :
Thanks
What about the PDFium git repo which I mentioned? Do I need to build PDFium using that git repo only?
yes, as documented in https://gdal.org/en/stable/drivers/raster/pdf.html#pdfium. There are multiple patches needed on top of upstream PDFium to get it compatible with the GDAL PDF driver
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250114/bdee56b9/attachment-0001.htm>
