[gdal-dev] Build GDAL PDF Driver with PDFium
Even Rouault
even.rouault at spatialys.com
Mon Jan 13 16:32:41 PST 2025
Le 14/01/2025 à 01:23, Parveen Sharma a écrit :
> Thanks Even
> As i am building GDAL 3.9.3, so i will use the scripts in the
> https://github.com/rouault/pdfium_build_gdal_3_9
> <https://github.com/rouault/pdfium_build_gdal_3_9> repository to build
> a patched version of PDFium.
> Would you recommend using the "master" OR the "pdfium_6309_v1" branch
> of the above repository? I need to build GDAL with PDF Dynamic driver
> in both Windows and Linux.
They're the same (except an edit in the readme file that doesn't matter
as far as doing builds is concerned)
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250114/dcffb855/attachment.htm>
