[gdal-dev] Removing write side of (SDK based) FileGDB driver ?
Even Rouault
even.rouault at spatialys.com
Tue Jan 14 10:59:50 PST 2025
Actually thinking that there isn't just update, but also pure creation.
2 potential options for that one:
- either just completely remove the Create() implementation of FileGDB.
Slightly backwards incompatible as users will have to change in their
code their "FileGDB" string to "OpenFileGDB"
- or make it just a shim that forwards the call to the OpenFileGDB driver
Le 14/01/2025 à 19:49, Even Rouault via gdal-dev a écrit :
> Hi,
> You all know my ever appetite to remove useless code (especially when
> I have to do painful exercices such as RFC 105 changes). This time I'd
> be very well tempted to axe the write side of the FileGDB driver (the
> one based on the Esri SDK). Unless I'm missing something, I don't
> think it provides anything that the write side of the OpenFileGDB
> driver wouldn't provide, and it comes with various hacks to overcome
> shortcomings of the SDK (some of the hacks involve relying on the
> OpenFileGDB driver...). The read side of the FileGDB driver is still
> useful for compressed datasets, so we can't unfortunately completely
> kill the driver. The change would make the FileGDB driver skip if
> opened in update mode so that the OpenFileGDB driver kicks in instead,
> so this should be unnoticed by users of the API (thinking here of a
> QGIS user that would have the FileGDB driver installed and switching
> to edit mode. The OpenFileGDB driver should be used. I'd have to test
> that theory)
> Thoughts?
> Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
