[gdal-dev] Removing write side of (SDK based) FileGDB driver ?
Even Rouault
even.rouault at spatialys.com
Wed Jan 15 10:20:12 PST 2025
Le 14/01/2025 à 19:59, Even Rouault via gdal-dev a écrit :
> Actually thinking that there isn't just update, but also pure creation.
> 2 potential options for that one:
> - either just completely remove the Create() implementation of
> FileGDB. Slightly backwards incompatible as users will have to change
> in their code their "FileGDB" string to "OpenFileGDB"
> - or make it just a shim that forwards the call to the OpenFileGDB driver
I've gone through the shim approach for Open(update=1) and Create(). The
OpenFileGDB driver is registered before the FileGDB one, so in update
mode QGIS would already use the OpenFileGDB one. I've also added the
CREATE_MULTIPATCH=YES layer creation option in the OpenFileGDB driver
that was AFAICS the only little piece missing. So all in all nobody
should notice the trick.
Close to 8000 lines of code full of hacks gone in
https://github.com/OSGeo/gdal/pull/11662 (last 2 commits). Hooray!
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
