[gdal-dev] GPU support for GDAL
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Wed Jan 15 05:21:44 PST 2025
The ovr is "just" a tiff with several "pages" (I do not know the exact
name). Like in the old times, using a scanner to scan several pages of a
document. (actually, there are some image viewers that show you this
opening a tiff with embedded overlays: several pages)
You can create that with gdal. Unfortunately I forgot the details.
On Wed, 15 Jan 2025 at 10:12, Pradeep Mahato via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
>   The problem i am facing is related to generating the overview(Pyramid)
> layer. GDAl has BuildOverview() function to build the pyramid layer and
> save it as a file with ".ovr" extension. The BuildOverview() funstion takes
> raster file as input and generate the layer.
>    As per project design application is generating these pyramid layer. my
> requirement is that is any function is  available in gdal where i can pass
> there multiple layers of pyramid and the function provides me a single
> ".ovr" file.
> ----- Original Message -----
> From: gdal-dev at lists.osgeo.org
> To: gdal-dev at lists.osgeo.org
> Sent: Friday, November 8, 2024 6:38:14 PM
> Subject: Re: [gdal-dev] GPU support for GDAL
> Pradeep Mahato via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> > In second approach i am facing issue in stacking and making it as one
> > ".ovr" file. So Pls help me in this regard.
> If you are going to ask for help, you should have your goals and
> software design in writing, and publish them.  Before doing that, you
> should have it reviewed by others in your organization.  Your message
> comes across as "I did something (but I'm not actually explaining what I
> did), and I didn't get what I wanted (but I'm not telling you what I
> wanted), so please do this for me".  Overall, it sounds like you need a
> consultant.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250115/8de4f3be/attachment.htm>
