[gdal-dev] Motion: adopt RFC 105: Add and use safe path manipulation functions
    Even Rouault
    even.rouault at spatialys.com
    Wed Jan 15 07:13:09 PST 2025
The candidate implementation is now ready (I'm afraid nobody will find
the energy to review the ~ 4000 different edits throughout the code
base... ) and all CI targets are green. *All* use of the deprecated C
versions has been removed from our C++ code (besides the place where
they are defined, and autotest code), and the few uses of them in C code
is OK. There's no risk of re-introducing them since their definition is
now hidden from GDAL C++ code.
So,
Motion: RFC 105 text: Add and use safe path manipulation functions:
https://github.com/OSGeo/gdal/pull/11640
Starting with my +1,
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250115/d2972644/attachment.htm>
